Budget (including currency): 2,500
Country: USA
Games, programs or workloads that it will be used for: gaming, streaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): i want to play gta v at minimum 80fps
https://linustechtips.com/topic/1259511-first-pc/
do you need monitor & Perfiereals?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1259511-first-pc/#findComment-14132285
Bios database
prior build:
https://linustechtips.com/topic/1259511-first-pc/#findComment-14132293
4 minutes ago, HelpfulTechWizard said:
That looks good and share this with all the people you know plz that use ltt.com.
https://linustechtips.com/topic/1259511-first-pc/#findComment-14132302
Do you need kb/m and monitor tho?
make sure you wait for a 5800x
Bios database
prior build:
https://linustechtips.com/topic/1259511-first-pc/#findComment-14132314
27 minutes ago, Linus rulz said:
Yes I need it all
ok, ill have to redo it.
Bios database
prior build:
https://linustechtips.com/topic/1259511-first-pc/#findComment-14132850
24 minutes ago, Linus rulz said:
Just changed budget to 2,000 usd
Holy shit. I guess you are getting a 3080 build.
Bios database
prior build:
https://linustechtips.com/topic/1259511-first-pc/#findComment-14133839
Bios database
prior build:
https://linustechtips.com/topic/1259511-first-pc/#findComment-14133864
https://linustechtips.com/topic/1259511-first-pc/#findComment-14134485
15 minutes ago, Linus rulz said:
32 gigs of ram to plz
and water cooling for cpu
its going to have to be a 3070 and 5600x probably.
Bios database
prior build:
https://linustechtips.com/topic/1259511-first-pc/#findComment-14134555
Bios database
prior build:
https://linustechtips.com/topic/1259511-first-pc/#findComment-14134623
Guest
