I would say you could as long as your use NVEC
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
4 minutes ago, EyeSii said:
Can I stream 1080p60 with a Ryzen 3 3100, GTX 1080 AMP EDITION, and RIPJAWS 16GB RAM 3600mhz?
Probably using GPU encoding you'd be fine, but GPU encoding on Pascal isn't great quality.
A CPU upgrade would probably help you if you're looking to upgrade.
I legit just upgraded from an i7-2600, RX 470 and 8GB of DDR3 RAM (single channel cause my motherboard broke) to a Ryzen 3 3100, GTX 1080 and 16 GB RAM, so what’s a good upgrade? A Ryzen 5 3600 ? Also what is “Pascal” I never heard of that term before ?
