I have a budget of a little over 2000 my current pc is a Alienware Intel core i5 eighth gen and I want to upgrade it. And I won’t stream only gaming and I want a fast computer with great graphics for the money I have to spend.
my list is
CPU Intel Core i5 10600K
Gpu Nvidia GeForce rtx 2070 super
CPU cooler iCUE H150i liquid cooler
Motherboard Asus prime z490 A
RAM Kingston hyperX 4000mhz DDr4
Storage seagate 3 TB 7200 rpm
ssd Samsung 970 Evo 1TB nvme
case Lian li Dynamic
Power suppply Corsair 2019 750W Bronze
operating system windows 10 64 bit
Case fan Corsair LL 120 triple pack (Two packs)
mouse golf Hati 2020 edition
keyboard ducky Miya Sakura
thanks for the tips you guys are great have a good day stay safe 🙂
https://linustechtips.com/topic/1259412-rate-my-pc-list/
Counrty? Can you wait for ryzen 5000? If in the USA, you could get a 3080 is a 2000$ build.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1259412-rate-my-pc-list/#findComment-14131147
Just now, boggy77 said:
get a 3070 instead
2k (if usd) can get a 3080. 1.3k for eveything but GPU is doable.
Bios database
prior build:
https://linustechtips.com/topic/1259412-rate-my-pc-list/#findComment-14131165
1 minute ago, TheLastWorm said:
But where do I get a 3080 I made this list of pcpart list but I know that the 30 series is hard to get but are all th others components good?
I would get a zen 3 cpu, if you are waiting for a 3080 to be available you could wait for a 5800x. Do you live in the usa.
Bios database
prior build:
https://linustechtips.com/topic/1259412-rate-my-pc-list/#findComment-14131180
9 minutes ago, TheLastWorm said:
Also should I get different ram or keep this one I was thinking 3600 MHz 4 4 Gb sticks
2 sticks are easier to run by the cpu memory controller than 4. always go for 2 sticks. that also leaves room for upgrade in the future.
https://linustechtips.com/topic/1259412-rate-my-pc-list/#findComment-14131228
Bios database
prior build:
https://linustechtips.com/topic/1259412-rate-my-pc-list/#findComment-14131439
