Can anyone tell me is this cable problem or might it power supply ?
500w +80 bronze
Ryzen 3600
Gtx 1080
16gb vengeance pro rgb
500gb nvme intel 660p
When im doing work my computer no ever have a problem but when gaming it wil shutdown at certain time?
The question is when play game the power supply not enough to run it then restart it's?
Sorry my bad English
CPU: AMD Ryzen 5 3600 | RAM: 32GB (2x8GB) Vengeance PRO RGB DDR4-3600 (White) | Motherboard: Gigabyte B450M Mortar Max | Storage: 1TB Samsung 990 Pro & 500gb NVME Kingston & 4TB Seagate & 1TB WD blue & 1TB 2.5 HDD WD | GPU: Zotac Intrinity OC RTX 3080 TI | Cooling: AMD PRISM | Case: Corsair 4000D Airflow | PSU: Superflower 850W
https://linustechtips.com/topic/1258984-auto-shutdown-pc/
Aerocool 500w +80 bronze underload no problems, but when heavy load playing heavy game cod, forza 4 , dota2 , destiny 2 and it start to shutdown again. Before this no problem but when i upgrade hdd 4tb this problem was happen in this month but today almost 8 time happen in 1 hour
https://linustechtips.com/topic/1258984-auto-shutdown-pc/#findComment-14127827
You should get a BETTER psu
Your current one It's probably in the D-tier in the PSU tier list. And that is not good.
Also - to make sure the person you are writing to reads the message quote their text in your post.
Pax vobiscum
https://linustechtips.com/topic/1258984-auto-shutdown-pc/#findComment-14127859
Traditionally crash after start is most often memory problems.  PSU problems have become very common though. Modern CPUs self overclock and can hit the PSU very hard for tiny moments.
https://linustechtips.com/topic/1258984-auto-shutdown-pc/#findComment-14127864
