Hello there,
Since I'm a complete noob at building a PC, I would like you to help me with choosing the parts.
Budget: 1500 - 1800 USD
Country: Bulgaria
Target: 60+ fps high settings on today's most demanding AAA games like Cyberpunk for example, at 1080p
Other: I'm also looking for a 1080p 144hz monitor, something along the lines of 300 USD that fit into the budget
https://linustechtips.com/topic/1258937-first-build-help/
41 minutes ago, Norwenn said:
Hello there,
Country: Bulgaria
Other: I'm also looking for a 1080p monitor, something along the lines of 300 USD that fit into the budget
here is a monster system include a 240 HZ G-sync monitor
your easily getting way higher then you expect from this list
https://linustechtips.com/topic/1258937-first-build-help/#findComment-14127557
4 hours ago, Alireza said:
Thank you very much! I'll trust your wisdom of PC building and get right to it!
https://linustechtips.com/topic/1258937-first-build-help/#findComment-14128017
