I run a editing machine where I render projects for 30 min - 5 hours straight at 100% cpu (3950x) and using all of my available ram (64gb),
I have a Asus motherboard (If that matters for the question below).
Question:
Is there any nice software that can monitor the temps I am getting with a good GUI that is simple like:
CPU temp : X
Thanks and sorry for the silly question
https://linustechtips.com/topic/1258506-program-with-good-gui-for-cpu-temps/
i use something called core temp. its ok by me but others may have something to say.
here is a screenshot of it:
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
x
Silly me, Thanks for the post!
I just saw "CAM", It has quite a nice GUI,
Is that application reliable? (Accurate)
My Task manager:
CAM:
never used it :(
but looks alright. what company has made this? is this the NZXT CAM thing?
also, what motherboard are you running right now? if you have msi, you can use dragon center and you can get a nifty little gui.
here is a screen shot:
but it is quite different from the cam one.
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
1 minute ago, eeeee1 said:
never used it :(
x
I use a Asus motherboard,
Yes NZXT CAM.
It does however seem to say lower cpu usage than Windows task manager, Or is Windows reporting wrong?
Yes NZXT CAM
ah i see. if you indeed have a NZXT aio i would imagine and hope that it would integrate very well with one
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
17 minutes ago, TriTexas said:
I don't, I have a Asus cpu cooler 😆
I will try Core temp, Where did you download it?
tbh i just looked up cpu temp monitor and found it.
https://www.alcpu.com/CoreTemp/
this seems to be the official site. (got directed to it by the application)
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
CAM has had issues in past where it uses more resources than needed. But then again, I don't think there's anything else that would be nice and easy from the start. Most of them rely on user to set it up first.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Question:
CPU temp : X
You could try Rainmeter with either AIDA64 + Rainformer or HWInfo + Rainformer (free) I have a post here on it..  You could just use it out of the box as it comes and turn on and off the displays (skins) you want to see. Very low overhead.
50515398783_736eb726dd_z.jpgRainformer_Fans_Update2 by Hilton, on Flickr
