Budget (including currency): $4500-$5000
Country: Australia
Games, programs or workloads that it will be used for: Competitive Gaming (Battle Royales ETC)
(I kinda don't want to wait for Zen 3 because its going to be more expensive than the Zen 2 CPU's)
OKAY so bit of a dilema-
i want to get the following CPU & GPU but i'm reading on reddit that i will be majorly bottleneck and not worth gettting the two together
Ryzen 7 3800XT
Gigabyte GeForce RTX3080 Aorus Extreme 10GB GDDR6X
Can you guys settle this for me! I don't trust people more than the LTT community
https://linustechtips.com/topic/1258308-new-build-help-pt2/
what resolution and rfresh rate? for 1440p and 4k it will be fine.
at 1080p, you're better off waiting for the ryen 5000 series.
you're spending 3-4k on a pc and you don't want to spend $100 more for 20% more performance? that's weird
https://linustechtips.com/topic/1258308-new-build-help-pt2/#findComment-14122055
