Hey guys,
I'm looking for a good black case for water cooling, it needs to support two 360 rads and it can only be 650mm high. I don't need any 5.25" bays. And I only need room for 1 SSD and 1 HDD, but other than that nothing is needed.
Bugdet: 250$
EDIT: Don't like brushed aluminum (Like the look of it, but not the actual thing)
EDIT EDIT: I have come to the conclusion that I will only need one 360 rad and a 240 or 280 rad
My setup: i5 3570K  - Corsair H100i - MSI Z77 GD65 - 256 GB Samsung 840 pro SSD - Corsair AX760i - Gigabyte GTX 670 Windforce 2GB - 4x4 GB Crucial Ballistix Tactical Tracer RAM - Corsair Carbide 500R (modded side window)
https://linustechtips.com/topic/125811-good-water-cooling-case/
Well, this have the things I need and in the right size. Although I'm not a fan of brushed aluminum, should have mentioned that in the top comment
https://linustechtips.com/topic/125811-good-water-cooling-case/#findComment-1672551
What's your budget?
Well... I would say that the max amount of money I have for a case is 250$
https://linustechtips.com/topic/125811-good-water-cooling-case/#findComment-1672626
If you don't like brushed aluminum then get the NZXT switch 810
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811146088
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/125811-good-water-cooling-case/#findComment-1672660
Doesn't fit dual-360 rad, right?
The OP could also go with a 360 and a really really thick 280 in some smaller cases (Primoo is the only one that supports dual-360 rads in that pricepoint to my knowledge, 900D is much taller, more expensive).
144Hz goodness
https://linustechtips.com/topic/125811-good-water-cooling-case/#findComment-1672697
NZXT H440 fits 2 360mm rads afaik.
Thanks for your replies guys, but after some thinking, I have come to the conclusion that I will only need one 360 rad and a 240 or 280 rad, if anyone have some suggestions to a case for a loop like that, I would very much appreciate it :)
The same criteria as before, just the rad support is changed.
https://linustechtips.com/topic/125811-good-water-cooling-case/#findComment-1673107
NZXT 440. Still.
https://linustechtips.com/topic/125811-good-water-cooling-case/#findComment-1673177
Ignore this comment :/
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/125811-good-water-cooling-case/#findComment-1673182
NZXT 440. Still.
Don't really like it's look, would rather have something that's completely black
https://linustechtips.com/topic/125811-good-water-cooling-case/#findComment-1673239
