Basic Overclocking Question
Go to solution Solved by Random_Person1234,
Just now, Ya_Mi said:
So just to make sure, all Ryzen CPU except the one that has "G" doesn't have an integrated graphics?
Yes, all desktop Ryzen CPUs without a G do not have an iGPU.
Hi guys, ive been living under a rock and pretty behind when it comes to tech and i am trying to catch up.
So, do i still need Z motherboard to overclock intel CPU? and what about the new Ryzen CPU?
Thanks in advance.
Behold the power of Chuck Norris the forbidden one.
https://linustechtips.com/topic/1257462-basic-overclocking-question/
To overclock an intel unlocked CPU (k series), you need a Z series mobo. For AMD, anything B or X Series supports overclocking with Ryzen.
CPU - Ryzen 5 5600X | CPU Cooler - EVGA CLC 240mm AIO  Motherboard - ASRock B550 Phantom Gaming 4 | RAM - 16GB (2x8GB) Patriot Viper Steel DDR4 3600MHz CL17 | GPU - MSI RTX 3070 Ventus 3X OC | PSU -  EVGA 600 BQ | Storage - PNY CS3030 1TB NVMe SSD | Case Cooler Master TD500 Mesh
Does all AMD CPU support OC?
and which AMD CPU has integrated graphics?
All Ryzen CPUs are unlocked. You can tell if a Ryzen CPU has an iGPU if it has a G at the end of its name, ex. Ryzen 5 3400g.
