[Help] Strix 1080ti OC
Go to solution Solved by RAS_3885,
12 minutes ago, plastikman said:
Hey guys,
Let me go straight to the point - MSI Afterburner or GPU Tweak II?
I've been using GPU Tweak and setting their Gaming profile as default.
However, I feel that I can get a better performance with some tweaks, or just by moving to Afterburner with some custom profile?
My Setup:
MOB: ROG Maximus X Hero
CPU: i7 8700k (running at 4.6MHz)
GPU: Strix 1080ti OC (Gaming Profile from GPU Tweak II)
Cooler: Kraken X62
RAM: RipJaws DDR4 2400 CL14 2x8gb (Yes, I know...)
PSU: Seasonic Focus Plus 750W Gold
In the end they both accomplish the same thing, so just use whatever you like more. Afterburner seems to be the most popular option.
Hey guys,
My Setup:
Cooler: Kraken X62
https://linustechtips.com/topic/1257306-help-strix-1080ti-oc/
Hey guys,
My Setup:
Cooler: Kraken X62
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1257306-help-strix-1080ti-oc/#findComment-14113555
Well, that's what I've noticed so far. At the end of the day, i'm just trying to get a custom setup either for GPU Tweak or Afternburner, if it'll have better performance. I'm not used to Afterburner, so it'll be great if I could get a good setup recommendation.
https://linustechtips.com/topic/1257306-help-strix-1080ti-oc/#findComment-14113739
