Re-Thermal paste it,..Don't go crazy with amounts,...just an amount for Full coverage of the Core edge to edge so No Hotspots,... it's a few years in at least as it is now...
Likely not as good as it once was and dried up..
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
3 minutes ago, Zalda_ said:
As it turns out it sags and when it sags it overheats bad (91C with 100% fans, clocks going down to 1200mhz)
That mean the sag affect contact between HSF and GPU die, put something to stop it from sagging?
And yes, repaste it as well.
Probably the cooler doesn't make good contact with the die when sagging, the same happened with my 390.
The card went from 40c to 90c as soon as under load. As I stress test it while holding it by the shroud, temps were fine.
The backplate (and not the cooler itself) came loosely screwed in from the factory. I tighten the screws without overtightening them and that fixed it for me.
While you're at it, you might as well change the thermal paste.
MOTHERBOARD: ASRock H97 Pro4 CPU: Intel Core i5-4460 @3.30 Ghz Intel Xeon E3-1271v3 @4.00 Ghz RAM: 32Gb (4x8Gb) Kingstone HyperX Fury DDR3@1600 Mhz (9-9-9-27)
GPU: MSI 390 8Gb Gaming Edition PSU: XFX TS 650w Bronze Enermax Revolution D.F. 650w 80+ Gold MOUSE: Logitech G502 Proteus Spectrum KEYBOARD: Monokey Standard Suave Blue
STORAGE: SSD Samsung EVO 850 250Gb // HDD WD Green 1Tb // HDD WD Blue 4Tb // HDD WD Blue 160Gb CASE: Fractal Design Define R5 Windowed OS: Windows 11 Pro x64 Bit
MONITORS: Samsung CFG7 C24FG7xFQ @144hz // Samsung SyncMaster TA350 LT23A350 @60hz Samsung Odyssey G7 COOLER: Noctua NH-D15
