Just now, FeIIex said:
Depending on where you buy it from, the store could flash it for you before shipping it out. Otherwise, you will most likely have to flash it with another CPU first
What he said, however. If the store will not flash it, AMD has a cpu loan program.
https://www.amd.com/en/support/kb/faq/pa-100
lttstore.com
https://linustechtips.com/topic/1256662-will-this-work-or-not/#findComment-14108268
At the beginning of a cpu life cycle you'll definitely need to flash the board beforehand. Both options above are proper
https://linustechtips.com/topic/1256662-will-this-work-or-not/#findComment-14108298
