Bottlenecking with GTX 1080 and a i5-7500 processor
ZoNeWasTaken
Hey, I have a GTX 1080 and a i5-7500 processor. I recently noticed that I’m getting some lag issues. Especially in CS:GO where I cap at 110 fps and usually get 70-80 fps. Is this my CPU bottle necking my GPU?
I’ve tried searching online for the same specs and they seem to get 200+ fps in csgo max settings. And I get around 80 with the lowest setting.
If I would get a 5900x processor would that help?
you don't need to get the best CPU possible, the Ryzen 5 5600X would hypothetically be a pretty massive upgrade by itself and offer some high end gaming performance.
but first, are you running 2x8GB of ram, or just one dimm?
Primary PC:
Also, I have a 550 watts powersupply, windows 64 bit and asus rog strix z270h motherboard
I have 2 of 8 gb ram making it 16 in total
dual channel ram does help but yes if your CPU is too slow in games you would need to upgrade
Primary PC:
Yeah, I most likely will. I’m just curious why CS:GO would lag that much, because I didn’t think it would bottleneck that bad.
