It obviously is going to work, but why 32gb of RAM? I would also advise against getting the 1660 ti. A 1660 super or $20-30 more for the 2060 (if you're not willing to wait for new GPUs) is a better deal.
Honestly, I think you should just wait. For $1.3k you can build a very good system in the next couple of months. A Ryzen 5 5600x with a 3070 or one of the new Big Navi GPUs would be a great system.
The more I learn, the more I realise I don't actually know anything.
Recommendations: Lian Li 205m (sleek, pretty decent airflow for a non-mesh front panel and cheap), i5-10400f (Ryzen 5 3600 performance, 20% cheaper), Arctic P14 PWM fans, Logitech g305.
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104867
i usually have a lot of tabs open for online school so thats why I have 32gs i had extra moneh so I was like why not
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104869
Chrome won't use 32 gb of ram unless you have literally hundreds open. What will you be using your pc for?
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104873
That's a terrible PSU, and it's so old it might give you issues with random shutdowns, not to mention dangerous voltage regulation. Grab this instead, it will be worth every penny. https://pcpartpicker.com/product/FdRFf7/corsair-cx-2017-550w-80-bronze-certified-atx-power-supply-cp-9020121-na
I recently RMA'd one of these almost 5 years after getting it, and the PSU itself didn't give any problems at all (it was the fan that started clicking). I can 100% vouch for Corsair's customer support, and for the quality of this unit.
Other people will have comment on other part choices.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104874
btw how much will the 5600x cost? including the   3070
If at msrp, around $800. I didn't see that you had included a monitor in your price, so a $1,000 build would be more in your budget. For that you can get a better GPU than the 1660 ti and a current or next gen CPU.
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104876
ya... im kinda doing a trail off of the ibuypower gaming pc bc they jacked up the prices
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104878
If you want the absolute best bang for buck, a used 1080 ti will cost you around $350 and performs almost exactly the same as a 2070 Super.
If you don't want to buy used, the RX 5700 XT starts at $380 and is a couple percentage points behind the 1080 Ti / 2070 Super. I'd say that's the best bang for buck for resolutions above 1080p.
That CPU cooler is going to be insufficient btw. It'll be very loud and very hot. The value for money option is the Deepcool Gammaxx 400, or grab a Hyper 212 RGB Black Edition if you want something nice looking.
Computer Specs:
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104879
The CPU and motherboard choices are weird, probably because it's stock that ibuypower has lying around. The modern options are B550 + Ryzen 7 3700X or Z490 + i7 10700k, if you really need 8 cores.
Computer Specs:
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104883
Have to agree. Unless you're using your computer for Video Editing/Rendering, CAD or another workstation task you should be fine with 16gb. You could use the money you'd save to get a bigger HDD.
CPU: Intel i9 9900K | Motherboard: ASRock B365M Phantom Gaming 4 | RAM: 4x8GB 2666MHz HyperX Fury RGB | GPU: ZOTAC GAMING GeForce RTX 3080 AMP Holo | PSU: Corsair RM750x (2018) | Case: ASUS TUF Gaming GT301 | Cooler: Cooler Master Hyper 212 Black Edition | SSD: Samsung 970 Evo 500GB | SSD: PNY XLR8 CS3030 2TB | SSD: Samsung 860 Evo 2TB | HDD: Seagate BerraCuda 8TB | Monitor: GIGABYTE G27QC
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104890
2 minutes ago, progamer21 said:
so wat graphics card should I get
What are you going to use the computer for?
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104891
fortnite, minecraft, online school
Any demanding games? Any plans for a 1440 or 4K monitor?
Computer Specs:
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104895
1660 Super should be fine for those games at 1080p.
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104899
31 minutes ago, progamer21 said:
For $30 you can get a better cooler.
CPU - Ryzen 5 5600X | CPU Cooler - EVGA CLC 240mm AIO  Motherboard - ASRock B550 Phantom Gaming 4 | RAM - 16GB (2x8GB) Patriot Viper Steel DDR4 3600MHz CL17 | GPU - MSI RTX 3070 Ventus 3X OC | PSU -  EVGA 600 BQ | Storage - PNY CS3030 1TB NVMe SSD | Case Cooler Master TD500 Mesh
https://linustechtips.com/topic/1256285-does-my-build-work/#findComment-14104907
