Noisy fans
Solved by Bwithnewcast,
On 10/11/2020 at 3:58 PM, bowrilla said:Well those temps are perfectly fine and it is to expected that you push your AiO to the max. The noise is on the noisy fans. As I said, those aren't particularly great and Corsair has a reputation for more noisy fans. There are no really great RGB static pressure fans. You'd probably be better off with the Phanteks Halos RGB frames on better non-RGB fans.
Okay, so what i found out is the fans are a little loud yes but i can live with that, but what i can't live with is that the radiator for my AIO is around 1/2 to 3/4 full
