Hi,
I'm wondering if someone have a good place to buy just the LCD's from. Not the backlight. I have three different monitors that need to be repaird.
1. Mi 34 curved panel is a LSM340YP05
2. NEC Multisync PA322UHD panel is Sharp LQ315D1LG9G
3. Benq something something panel isM240HW01 v.8
https://linustechtips.com/topic/1256155-lcd-replacment-with-no-backlight/
Ebay / Aliexpress.
Just search for the panel number.
Plenty of choices up to 27 inch.
The curved one is probably the hardest to find.
Are you absolutely sure it's the LCD panel not the board?
because if not broken LCD panel can last a very long time.
22 hours ago, SupaKomputa said:
Ebay / Aliexpress.
Im 100% sure its the LCD(all three häve fall damage)
The 24" is allready sorced, not the curved and Nec...
If it has cracked yes nothing will save it but screen replacement.
The thing with the screens on Ali and Ebay is that I only find the whole assembly, with Screen and backlight etc. I just want the Screen
