Running two separate Nvidia cards
Go to solution Solved by TehDwonz,
33 minutes ago, PuffTheRainboWUnicorn said:
Quick question. I've been upgrading my PC piece by piece and the final thing to do is my GPU, I'm currently running a GTX 1050 and am planning to upgrade to one of the RTX cards.
And there lays the problem, my main monitor is a HDMI monitor so that's fine, but my second is a DVI-D monitor, so I was wondering, could I keep my 1050 in my system and use it to run the second monitor, while using the RTX card for games and my primary monitor, or will I have to use a single monitor setup for a while until I get a new screen?
Any help is appreciated, thank you.
Yes, under Windows 10, this will work fine. The only issue that may come up (much) later is a driver mis-match when the 10 series is dropped. That's some way off though, but keep it in mind if you end up not getting a new monitor for a while.
https://linustechtips.com/topic/1256082-running-two-separate-nvidia-cards/
well the support for 10 series is up at least for another 5 years
if it was useful give it a like :) btw if your into linux pay a visit here
