SSD RAID0 Speed Bottleneck.
Solved by WereCatf,
2 minutes ago, Linksys120n said:much higher?
You'd probably get sequential read-speeds of 800MB/s or more, so yes.
3 minutes ago, Linksys120n said:so it would matter if the use is a steam game cache?
Not really. The way games are currently designed, even a single SATA SSD is plenty and you won't get that much benefit from even faster storage, because the bottleneck will be on the CPU-side. In the future, games will likely be designed to take better advantage of SSDs, especially NVMe-drives with RTX IO and Microsoft's Direct Storage.
You will probably get a small bump from RAID0 over non-RAID, but don't expect any big difference. Just having an SSD of any kind, instead of a mechanical drive is the biggest boost.
