3 minutes ago, jonnyGURU said:
You can buy a Corsair PCIe cable separately.  And it will be 6+2 which works as a 6-pin or an 8-pin, so you don't need an adapter.
What country are you in?
also i thought those cables 8 pin on the psu side my psu only has 6 pin connectors on it
https://linustechtips.com/topic/1255879-psu-cable-confusion/#findComment-14101454
7 minutes ago, heckn hecker said:
i am planning on upgrading my graphics card from a 1050 ti to a 1660 ti but i dont have the pcie cables for my psu anymore it is a corsair cx550m and i also will need to adapt a 6 pin to a 8 pin connector pls help
The Corsair CX550M has TWO PCI-E 6+2 power cable connections.
They work as either PCI-E 6-pin, or PCI-E 8-pins ...by combining the extra 2 cables from the 6+2 wiring...
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1255879-psu-cable-confusion/#findComment-14101460
3 minutes ago, hwhendhah said:
Just buy a new psu. CXM is not a reliable psu yet it's grossly overpriced
Who pissed in your Wheaties?   😄
I'm really curious as to what you would suggest replacing a perfectly working CX550M with, for an entry level system like OP's during a time when ALL PSUs are grossly overpriced.
https://linustechtips.com/topic/1255879-psu-cable-confusion/#findComment-14101524
