gpu First gaming pc build
Solved by Fasauceome,
3 minutes ago, Damra said:pcPartPicker says that the motherboard may not be compatible out of the box
I highly recommend a B450 motherboard instead of A320 because it will give support for 5th gen Ryzen in the future. If you want guaranteed support, one of the MAX motherboards from MSI is updated for third gen. A520 is also guaranteed to support and will support fast ram, which is important for ryzen performance.
Not sure how much fresh stock is in Jordan in terms of motherboards but every B450 motherboard made after a certain date is updated for ryzen, while A320 motherboards only get it on a Beta BIOS so it's unlikel that you'll but an A320 motherboard that's compatible with ryzen.
