http://linustechtips.com/main/topic/122064-my-rig-for-2014/   <<<<<<<<This is the log for my PC build. After i built this PC it just sat on the floor next to my desk on the carpet, so i needed to raise it up for better airflow and so my dumbass didn't spill anything through the top exhaust holes. I also needed a shelf to place my router, headphones, ect. And the best part is it is made out of junk wood from some other projects i have done around the house, so i didn't have to spend any money in order to build it.
Here is the top part during assembly
With the legs attached
With shelf attached
Sanded, Stained, and completed
Fits my 750D perfectly!
A shot of the bottom, i left the bottom open for better airflow through the bottom intakes and power supply fan (notice the epic filter off the top of the case i cut to fit and put Velcro on)
My setup now with stand
Thanks for taking a look, if you have any questions feel free to ask.
https://linustechtips.com/topic/125528-pc-stand-build/
What keyboard is that?
It's the Ducky: Year of the snake
Though it looks like it has been modified.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/125528-pc-stand-build/#findComment-1668673
I like it. Good job, my fellow Techtipian.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/125528-pc-stand-build/#findComment-1669041
