Hello guys,
This is my first time posting something on the forum so please tell me if I'm doing something wrong :).
So now my question:
I want to upgrade my 7870 XT and my budget is around €300. My other specs are: FX-8350 @ 4.8 ghz; 8gb 1600mhz ram; asus sabertooth 990fx; samsung 830 128gb ssd and I play at 1080p.
I can get 2 used Asus 7950's for ~€340 from a friend. Or I could get a new R9 280x for ~€260. Or something else...? I'm not really sure what to get so please help.
Thanks.
Ps. I'm from the Netherlands so forgive me if my English isn't correct :)
https://linustechtips.com/topic/125511-upgrade-help/
Hello guys,
So now my question:
Thanks.
Both will be an improvment. But the 7950Xfire is a nice upgrade, if they still run nicely and so on that is.
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/125511-upgrade-help/#findComment-1668447
Hello guys,
So now my question:
Thanks.
 I'd just go with a 280x then buy another one in the future.
What's your power supply? You need a decent power supply to run two 7950s.
Both are viable options.
https://linustechtips.com/topic/125511-upgrade-help/#findComment-1668472
