i have a newer case and old power suply that i want to use in a new build for my house pc witch is mostly a plex pc but i quit gaming on it because it got to old now i want to upgrade to
GIGABYTE B450M DS3H AM4 AMD B450 SATA 6Gb/s Micro ATX AMD Motherboard
SquareTrade Protection Plan
  • 3 Year Motherboard Protection Plan: $9.99
  • 4 Year Motherboard Protection Plan: $12.99
In Stock
  • $74.99
In Stock
Limit 10
  • $78.98
AMD Ryzen 7 2700X 8-Core 3.7 GHz (4.3 GHz Max Boost) Socket AM4 105W YD270XBGAFBOX Desktop Processor
  • 3 Year CPU Protection Plan: $29.99
  • 4 Year CPU Protection Plan: $39.99
In Stock
Limit 5
  • $329.99
  • $219.99
  • Save: 33.33%
Western Digital WD Blue SN550 NVMe M.2 2280 1TB PCI-Express 3.0 x4 3D NAND Internal Solid State Drive (SSD) WDS100T2B0C
  • 3 Year SSD Protection Plan: $15.99
  • 4 Year SSD Protection Plan: $22.99
Recover Your Data
View Details
In Stock
Limit 3
  • $129.99
  • $104.99
  • Save: 19.23%
https://linustechtips.com/topic/1255047-help-with-pc-build/
Cou
ld
You
ple
ase
fix
the
po
st
What is your current PSU and how old is it?
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1255047-help-with-pc-build/#findComment-14093322
In Stock
  • $74.99
In Stock
Limit 10
  • $78.98
In Stock
Limit 5
  • $329.99
  • $219.99
  • Save: 33.33%
Recover Your Data
View Details
In Stock
Limit 3
  • $129.99
  • $104.99
  • Save: 19.23%
Personally I would pay the extra 45 bucks for the 3600X, you'll also be able to use more mhz on that RAM compared to the 2700X
I have that exact SSD and I would recommend it
https://linustechtips.com/topic/1255047-help-with-pc-build/#findComment-14093403
37 minutes ago, Saearrin said:
Are you in a hurry to build this PC? Don't think it's a good idea to build a machine with a 2nd gen Ryzen when the 4th gen is literally just a few weeks away.
maybe a budget constraint?
PLEASE TAG ME SO I CAN SEE YOUR REPLY!
CPU: AMD Ryzen 7 3700x  | Motherboard: Asus TUF X570 Plus | RAM: Crucial Ballistix 8gbx2 3600Mhz | GPU: Asus TUF RTX 3080 | PSU: NZXT C850 | Case: Corsair 5000D AF | Cooler: NZXT Kraken Z63 280mm | SSD: Samsung 970 EVO 500Gb m.2 ssd + Samsung 860 EVO 1tb ssd | Monitor: LG 49WL95C-W | Peripherals: Logitech G815 + Razer Viper Ultimate + Razer Kraken TE | Audio: Logitech G560
https://linustechtips.com/topic/1255047-help-with-pc-build/#findComment-14093420
18 minutes ago, Saearrin said:
Even more of a reason to wait for the 4th gen. Supposedly 3rd gen pricing will drop.
Zen 3 will literally be announced tomorrow, so no reason not to wait.
CPU - Ryzen 5 5600X | CPU Cooler - EVGA CLC 240mm AIO  Motherboard - ASRock B550 Phantom Gaming 4 | RAM - 16GB (2x8GB) Patriot Viper Steel DDR4 3600MHz CL17 | GPU - MSI RTX 3070 Ventus 3X OC | PSU -  EVGA 600 BQ | Storage - PNY CS3030 1TB NVMe SSD | Case Cooler Master TD500 Mesh
https://linustechtips.com/topic/1255047-help-with-pc-build/#findComment-14094751
im not in much of a hurry my mb is starting to show its age and i have been losing sata ports that being said i think i need to upgarde before i lose data have 3 almost full 2tb drives for plex just wondering what ppl thought before i buy new stuff. i might get back into some gaming if i can get a used 2080ti for cheap but other than that i dont use my computer for much.
https://linustechtips.com/topic/1255047-help-with-pc-build/#findComment-14099391
