Will this build work?
Solved by Question mark??,
On 10/6/2020 at 11:20 PM, Fasauceome said:
not sure how that vertical airflow on the right works, if air comes right in through the front radiator it'll go straight back, not straight up and down
as for the founders edition 3080, half of the air is ejected out straight back and half is straight up, into the airflow path. if you're not using the founders edition, it'll all just go straight up.
I knew nothing of cases when posting this and had not slept in 20 hours. Now when I am more clearminded i see my stupidity. Thx for all your attempt to solve this hopeless thread I got this topic all sorted out now
