Hi all,
I am looking for a keyboard and mouse to go with my laptop. It will be used mostly when I'm at home and will stay at my desk. I want it to be wireless because I already have enough cords on my desk. I am looking for a keyboard that is good for typing, as I am in college and type A LOT. I also would prefer a large mouse, as I have large hands.
Thanks for any suggestions,
Erty
Does not having a second parenthesis around something bother anyone else as much as it does me? (Like if this statement was missing a second side)
https://linustechtips.com/topic/125371-wireless-keyboardmouse-combo/
Logitech combos are quite good:
http://www.logitech.com/en-us/keyboards/keyboard-mice-combos
If you have enough money the Performance MX is an exelent mouse and the keyboard is backlit:
http://www.logitech.com/en-us/product/wireless-performance-combo-mx800?crid=27
Main PC:
ASUS F1A55-M LX, AMD A6-3500, (2x2)gb Kingston HyperX Blu DDR3 1600mhz, Seagate Barracuda 500gb 7200rpm,
 Corsair CX430M, Cooler Master Elite 343, Windows 8.1 Pro 64-bit
Netbook:
Lenovo Ideapad S10-2, Intel Atom N280, (1x1)gb DDR2 667mhz, WD Scorpio Blue 250gb 5400rpm, Zorin OS 9 Lite
I second the MX Performance from Logitech.
I've had mine for over a year and constantly find myself trying to hit the scroll wheel change button so I can scroll fast through a long page when I'm not using it.
I also use a K270 from Logitech with it linked to the one receiver which is a real bonus when you're on a laptop and have a very limited amount of USB ports.
I have videos on both if you want them
"Everybody wants a happy ending, right? But it doesn’t always roll that way." - TS
If I get a Logitech keyboard with a unifying receiver, can I then get a separate Logitech mouse and use it with the same receiver?
If said mouse is also Unifying compatible (it comes with a Unifying receiver too) then yes. You just link them both to one receiver and leave the spare one in the box.
If the mouse supports it, yes.
purchased a k270 with mx performance mouse. should be coming in the next few days.
