Cant load microcenter.
Can you just list it here?
https://linustechtips.com/topic/1252975-build-help/#findComment-14075623
yeah- could you also tell me what is unnessesary
Intel - Core i7-9700K Coffee Lake 3.6GHz Eight-Core LGA 1151 Boxed Processor
ASUS - Z390-A Prime Intel LGA 1151 ATX Motherboard
G.Skill - Ripjaws V 16GB (2 x 8GB) DDR4-3200 PC4-25600 CL16 Dual Channel Desktop Memory Kit F4-3200C16D-16GVKB - Black
Lian Li - 205 Tempered Glass ATX Computer Case - White
PowerSpec - 650 Watt 80 Plus Bronze ATX Semi-Modular Power Supply
EVGA - GeForce RTX 2060 KO Ultra Overclocked Dual-Fan 6GB GDDR6 PCIe 3.0 Graphics Card
Samsung - 860 EVO 1TB SSD 3-bit MLC V-NAND SATA III 6Gb/s 2.5" Internal Solid State Drive
Seagate - BarraCuda 2TB 7200RPM SATA III 6Gb/s 3.5" Internal Hard Drive
Thermaltake - UX100 ARGB Universal CPU Cooler
Arctic Silver - 5 High-Density Polysynthetic Silver Thermal Compound 3.5g
Microsoft - Windows 10 Home 64-bit OEM DVD - English
Cooler Master - SickleFlow Rifle Bearing 120mm Case Fan (2)
https://linustechtips.com/topic/1252975-build-help/#findComment-14075659
Are you in a hurry, there's a new processors lineup from AMD that you can buy probably at 20 oct.
You can get a better CPU for the price of 9700K.
notes for the above specs:
- don't buy samsung 860, it's expensive, better get a Crucial P1 or WD Blue SN550 or 750.
- Windows OEM keys are cheap like $10-20.
- 2060 may not be good enough for VR.
https://linustechtips.com/topic/1252975-build-help/#findComment-14075705
1 minute ago, truckerlenny1990 said:
id say wait for cpu see what amd comes out with in a couple weeks. also the rtx3070 gpu will be out soon as well so that would be a huge upgrade from the 2060
lol, its not "soon" anymore, its like a month.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1252975-build-help/#findComment-14081931
