Can anybody help me out with some tech support!?
Having an issues with the system crashing randomly, I thought it was the memory which has now been RMA'd, I did a repair install of windows and and it's been running for a couple of day without issues which was an improvement, now just tried to play Doom for 20 min or some and it crashed and reset with no dump file.
I need help, can't figure out the issue and I'm pretty tech savvy!
https://linustechtips.com/topic/1252885-system-crashing-help/
DDU the GPU drivers, and reinstall.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1252885-system-crashing-help/#findComment-14074592
@Fontaine
What about the make and model of your power supply?
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1252885-system-crashing-help/#findComment-14074857
4 minutes ago, BlackManINC said:
@Fontaine
can't remember the make but is 80 bronze rated 750 watt, it's a but old now mind you.
Re the memeory
Corsair Vengeance LPX Black 32GB 3600 MHz DDR4 Quad Channel Memory Kit
32GB (4x8GB) Corsair DDR4 Vengeance LPX Black, PC4-28800 (3600), Non-ECC Unbuffered, CAS 18-22-22-42, XMP 2.0, 1.35V
I'm still wonder if that could be the issue?
https://linustechtips.com/topic/1252885-system-crashing-help/#findComment-14074877
15 hours ago, Fontaine said:
Quad channel, all slot filled... That could actually be the issue. Does ryzen support quad channel.... Pc part picker recommend the memory but actually....
it still runs them in dual channel. ryzen has a bit harder time to run 4 sticks of ram, might want to increase SOC voltage to 1.1 and see if that solves it
https://linustechtips.com/topic/1252885-system-crashing-help/#findComment-14076814
😒 Its odd how all these nerds across the internet that reviewed these CPUs neglected to mention this. Would enabling Precision Boost Overdrive work or is that totally useless?
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1252885-system-crashing-help/#findComment-14077681
that's a different thing. it's an auto-overclocking of the cpu. enable it only if you have an aftermarket cooler.
https://linustechtips.com/topic/1252885-system-crashing-help/#findComment-14077734
🤔 But doesn't PBO handle SOC voltages as well? I just stuck with the stock cooler, works perfectly fine for me. With PBO enabled it stays below 60C.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1252885-system-crashing-help/#findComment-14077845
no, pbo doesn't change soc voltage.
and yes, pbo will work with the stock cooler, but it doesn't mean that will give you any extra performance comparet to stock
https://linustechtips.com/topic/1252885-system-crashing-help/#findComment-14077857
🤔Hmmm, well, I expect at least a 30% performance boost over stock settings once I get a better GPU based on the videos I've seen.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1252885-system-crashing-help/#findComment-14077903
So issue still here. So far changed out the RAM and the PSU (including all wires) and still getting a Kernel 41 error.
It was working for 8 hours today then it did a few resets with the same error code but my system files are corrupted.
Having a total nightmare with this :(
https://linustechtips.com/topic/1252885-system-crashing-help/#findComment-14083686
And you tried increasing the SOC voltage settings?
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1252885-system-crashing-help/#findComment-14083775
