Link for 8 Pro
Go to solution Solved by xXxYOLOxSWAGxXx_420BlazeIt,
I believe so?
I checked the Code of Conduct and they only mentioned cracks, keys, or TV shows.
I will PM you the think though. The mods here arent the brightest people.
Hello everyone,
Does anyone have a direct link for windows 8 pro iso?
i have a product key but need a download link
(NOT A TORRENT)
System: 5930K, MSI X99 SLI PLUS, GTX 780Ti (SLI),  840 EVO, Fractal R4 (Full Custom Loop)  (IP)
Media Server/Perm Folder: i3 4130, CX500, 4 X WD Red 1TB, 60GB Adata SSD for boot, Node 304, ASrock Z87-E ITX, 8GB Kingston Value Ram
https://linustechtips.com/topic/125286-link-for-8-pro/
You wont find one that isnt a torrent. just putting that out right now.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/125286-link-for-8-pro/#findComment-1665706
Hello everyone,
(NOT A TORRENT)
A torrent is fine if you have the CD KEY.
It's not illegal if you have one.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/125286-link-for-8-pro/#findComment-1665711
i know, but torrents always seem to take longer for me.
https://linustechtips.com/topic/125286-link-for-8-pro/#findComment-1665715
That's the only way unless you have the CD itself.
https://linustechtips.com/topic/125286-link-for-8-pro/#findComment-1665716
Ok,
Thanks anyway
https://linustechtips.com/topic/125286-link-for-8-pro/#findComment-1665721
Microsoft used to have .iso downloads for windows 7 available on their servers for free. They haven't given windows 8 the same treatment though for some strange reason (yet?)
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
https://linustechtips.com/topic/125286-link-for-8-pro/#findComment-1665746
I can get you a direct link to the UK one if you want?
Is the link allowed to be posted here?
I believe so?
https://linustechtips.com/topic/125286-link-for-8-pro/#findComment-1666236
