I want a build that can get high frames, like 300 400 frames in games like R6, Val, Minecraft, Gta 5 and stuff while running all high or like shaders and stuff, I want to try and achieve that, budget can be around $10000 to $15000 I guess. Like if possible, like 4 to 2 3090 tis, if possible. Also like it is a workstation, I do digital art, 3d rendering and editing, heavy duty, so it will be worth it. Please reply with the buid.
https://linustechtips.com/topic/1252160-high-frames-comp-rtx-shader-build-help/
buying in the united states? buying at all? this does seem like a bit of a fantasy build.
Primary PC:
PSU tier list
How many watts do I need?
Why? There's barely a difference at all between 144hz and 240hz let alone a 360hz monitor. Also some of those games don't even allow fps that high.
Is this a fantasy build?
Also sli is dead so basically a single 3090 is where it stops for games.
-Locked-
Please don't post fantasy/dream build requests.
Guest
