hi,
I have this old bluetooth Apple keyboard and Apple Mouse. I was wondering if I will beable to connect them to my pc? I want to use them so that I dont have to use my super loud mechanical keyboard. (my family gets annoyed lol)
Here are the model numbers:
keyboard: magic keyboard model a1314
mouse: magic mouse model a1296 3vdc
https://linustechtips.com/topic/1251926-will-these-kbm-connect/
Assuming you are on windows 10 and have Bluetooth, just follow this guide.
https://www.google.com/amp/s/windowsreport.com/apple-keyboard-mouse-windows-10/%3famp
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1251926-will-these-kbm-connect/#findComment-14065860
57 minutes ago, PineyCreek said:
Pretty sure Apple doesn't support it (naturally), but I would think it should work in other OSes assuming you have bluetooth in your PC and it's enabled (stack installed/enabled, successfully paired, etc.).
ok thanks guys! Im going to get a bluetooth adapter for my pc but i just checked to see if it connected on another old pc with bluetooth and it worked!
https://linustechtips.com/topic/1251926-will-these-kbm-connect/#findComment-14065953
