So im having weird problems and i think it may be software related but i really don't know, here is a list of my hardware:
cpu:http://www.newegg.com/Product/Product.aspx?Item=N82E16819113348
ram:http://www.newegg.com/Product/Product.aspx?Item=N82E16820231720
mobo:http://www.newegg.com/Product/Product.aspx?Item=N82E16813130661
ssd:http://www.newegg.com/Product/Product.aspx?Item=N82E16820211596
gpu:http://www.newegg.com/Product/Product.aspx?Item=N82E16814130334
OS: windows 8.1
the problem i have is with any game but sc2, im lucky if i get 5 frames and i know i have a old gpu however i can still play sc2 just fine, any task that is not within a game works just fine but when ever i try to play d3 or any other game it lags and crashes, i think the problem is driver related because all the hareware works just fine... however i dont really know what the problem is.... if anyone has had any problems like this with any of the following hardware let me know... thanks
CPU: AMD 760k @4ghz | Motherboard: MSI fm2-a55-e33 | RAM: G. skill 4gb @1833 | GPU: AMD HD 7850 | Case: Nzxt 210 Tempest (with glass window mod) | Storage: Adata 128gb ssd | PSU: Raidmax rx-530ss | Display: 720p crap | Cooling: CoolerMaster sickleflow 120 green x4 | Keyboard: crap | Mouse: Razer diamondback | Sound: logitech 2.1 speakers | Operating System: Windows 7 Ult | Battle.net: Voldras #1712
https://linustechtips.com/topic/125179-weird-problems-drivers-maybe/
fm2-a55m-e33
amd 760k
evga 9600 gt
gskill 4gb 1866
Make sure all of your updates are current
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
I think they are.... or at lest it keeps telling me they are
Look at your system logs and see what the complete error is and if there are any other errors.
you mean something that looks like this? Total text=21013 THERAYNRIG KRyan Tribes PC 32-bit INT 2014.03.08-20.38.26 7748 742347 -PGUID=84cf6144-7f86-4ac8-a9e8-be839a56a95f  -host=63.251.64.141 -seekfreeloading  -aka=1000 -usereduxcache -browserpreload  -LANGUAGE=ENG -HiCommand -HEXX=1981FB66 C:\Program Files (x86)\Hi-Rez Studios\HiRezGames\tribes\binaries\Win32\ Fatal error!
Well no, right click my computer go to manage from there even viewer, windows logs, systems and while your there look at applications
i found it but... what am i looking for
something like this?
Log Name:      System
Source:        nvlddmkm
Date:          3/8/2014 9:19:01 PM
Event ID:      14
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      TheRaynRig
Description:
The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Event Xml:
  <System>
    <Provider Name="nvlddmkm" />
    <EventID Qualifiers="49322">14</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2014-03-09T05:19:01.479075100Z" />
    <EventRecordID>1915</EventRecordID>
    <Channel>System</Channel>
    <Computer>TheRaynRig</Computer>
    <Security />
  </System>
  <EventData>
    <Data>
    </Data>
    <Data>
    </Data>
    <Binary>0000000002003000000000000E00AAC0000000000000000000000000000000000000000000000000</Binary>
  </EventData>
</Event>
Has this been happening since you updated you geforce ?
the same problem happened when i was using a ati x1950
here is a few more errors:
Log Name:      System
Source:        Service Control Manager
Date:          3/8/2014 8:47:22 PM
Event ID:      7023
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Description:
The Superfetch service terminated with the following error:
The service has not been started.
Event Xml:
  <System>
    <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
    <EventID Qualifiers="49152">7023</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8080000000000000</Keywords>
    <TimeCreated SystemTime="2014-03-09T04:47:22.698236800Z" />
    <EventRecordID>1794</EventRecordID>
    <Correlation />
    <Execution ProcessID="584" ThreadID="800" />
    <Security />
  </System>
  <EventData>
    <Data Name="param1">Superfetch</Data>
    <Data Name="param2">%%1062</Data>
    <Binary>5300790073004D00610069006E000000</Binary>
  </EventData>
</Event>
Log Name:      System
Source:        Microsoft-Windows-Kernel-Power
Date:          3/8/2014 6:38:50 PM
Event ID:      41
Task Category: (63)
Level:         Critical
Keywords:      (2)
User:          SYSTEM
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
  <System>
    <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
    <EventID>41</EventID>
    <Version>3</Version>
    <Level>1</Level>
    <Task>63</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000002</Keywords>
    <TimeCreated SystemTime="2014-03-09T02:38:50.023299200Z" />
    <EventRecordID>1743</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="8" />
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="BugcheckCode">0</Data>
    <Data Name="BugcheckParameter1">0x0</Data>
    <Data Name="BugcheckParameter2">0x0</Data>
    <Data Name="BugcheckParameter3">0x0</Data>
    <Data Name="BugcheckParameter4">0x0</Data>
    <Data Name="SleepInProgress">0</Data>
    <Data Name="PowerButtonTimestamp">0</Data>
    <Data Name="BootAppStatus">0</Data>
  </EventData>
</Event>
Log Name:      System
Source:        EventLog
Date:          3/8/2014 6:38:53 PM
Event ID:      6008
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Description:
The previous system shutdown at 5:24:39 PM on ‎3/‎8/‎2014 was unexpected.
Event Xml:
  <System>
    <Provider Name="EventLog" />
    <EventID Qualifiers="32768">6008</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <TimeCreated SystemTime="2014-03-09T02:38:53.000000000Z" />
    <EventRecordID>1735</EventRecordID>
    <Security />
  </System>
  <EventData>
    <Data>5:24:39 PM</Data>
    <Data>‎3/‎8/‎2014</Data>
    <Data>
    </Data>
    <Data>
    </Data>
    <Data>6</Data>
    <Data>
    </Data>
    <Data>
    </Data>
    <Binary>DE07030006000800110018002700D302DE07030000000900010018002700D3023C0000003C000000000000000000000000000000000000000100000000000000</Binary>
  </EventData>
</Event>
Log Name:      System
Source:        Microsoft-Windows-DNS-Client
Date:          3/8/2014 5:29:23 PM
Event ID:      1014
Task Category: (1014)
Level:         Warning
Keywords:      (268435456)
User:          NETWORK SERVICE
Description:
Name resolution for the name client.wns.windows.com timed out after none of the configured DNS servers responded.
Event Xml:
  <System>
    <Provider Name="Microsoft-Windows-DNS-Client" Guid="{1C95126E-7EEA-49A9-A3FE-A378B03DDB4D}" />
    <EventID>1014</EventID>
    <Level>3</Level>
    <Task>1014</Task>
    <Opcode>0</Opcode>
    <Keywords>0x4000000010000000</Keywords>
    <TimeCreated SystemTime="2014-03-09T01:29:23.132327700Z" />
    <EventRecordID>1728</EventRecordID>
    <Correlation />
    <Execution ProcessID="1268" ThreadID="2304" />
    <Security UserID="S-1-5-20" />
  </System>
  <EventData>
    <Data Name="QueryName">client.wns.windows.com</Data>
    <Data Name="AddressLength">128</Data>
    <Data Name="Address">1700000000000000FD9F4662F7F80001FA8FCAFFFE06A8200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</Data>
  </EventData>
</Event>
Log Name:      System
Date:          3/8/2014 5:09:52 PM
Event ID:      41
Task Category: (63)
Level:         Critical
Keywords:      (2)
User:          SYSTEM
Description:
Event Xml:
  <System>
    <Level>1</Level>
    <Task>63</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2014-03-09T01:09:52.772204200Z" />
    <EventRecordID>1656</EventRecordID>
    <Correlation />
  </System>
  <EventData>
    <Data Name="SleepInProgress">6</Data>
    <Data Name="BootAppStatus">3221225684</Data>
  </EventData>
</Event>
Log Name:      System
Source:        Microsoft-Windows-Kernel-Boot
Date:          3/8/2014 5:09:51 PM
Event ID:      29
Task Category: None
Level:         Error
Keywords:
User:          SYSTEM
Description:
Windows failed fast startup with error status 0xC00000D4.
Event Xml:
  <System>
    <Provider Name="Microsoft-Windows-Kernel-Boot" Guid="{15CA44FF-4D7A-4BAA-BBA5-0998955E531E}" />
    <EventID>29</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000000</Keywords>
    <TimeCreated SystemTime="2014-03-09T01:09:51.740938700Z" />
    <EventRecordID>1640</EventRecordID>
    <Correlation />
  </System>
  <EventData>
    <Data Name="FailureStatus">3221225684</Data>
    <Data Name="FailureMsgId">5901834821891896</Data>
  </EventData>
</Event>
i have no clue what any of this means but hopefully you do...
Well the system DNS error is just your computer loosing internet connection.
As for the error 41 are you overclocking anything?
Also try checking device manager and see if there are any un-recognized devices.
i was overclocking but i changed it back to normal. and no
Set your BIOS to stock settings and everything else.
been there done that
Do you have an extra HDD you can install windows on?
no
it died, thats y i have the ssd. why?
Well you can always try than and see if the issue still exists. Alot of problems are hard to help with unless your on the computer
you sure that there's nothing that i can do? something out of blue? I've had to re install windows multiple times now and i don't want to do it again, I'll do anything but that unless that's the only option.
Try switching pci lanes for the graphics card.
Run heaven and see how it preforms
Well I just installed windowe 7 and now everything runs great, and I swapped out the 9600 gt for my X1950 pro (cuz it works better) so thanks for all the help anyway
