logitech z906 decode problem
I am using Logitech Z906 speakers with my computer sound card "sound blaster z" and I use optical connection however after short playing any audio the decode led turn off and sound as well turn off !! to turn it on again I have to open sound blaster control panel software and select either dolby digital or dts . Is there a fix to this problem ?
https://linustechtips.com/topic/1251746-logitech-z906-decode-problem/
