Ive just built my first pc and it worked perfect for the first 2 days but after spending like 45 minutes on it the 3rd day monitor goes to sleep and says displayport no signal
i restarted the pc and it worked for 30 minutes then again monitor went to sleep if i try restarting nothing works
i tried the monitor on another pc and it worked fine so i guess its hardware related problem
i tried using both hdmi and display they dont work
i tried without the gpu (rx 590 fatboy)
checking both ram sticks 2x8gb 3600mhz they work well.... i think....
i removed the mobo battery (gigabyte b450 gaming x and cpu is ryzen 5 3600) for 30 mins
i checked the cables a million times i dont know why its not working
the PC boots up but dosent send signal to monitor restarting also dosent help ( very rare it works but then the monitor shuts down in like 5 mins)
i dont know what to do anymore
so specs are
windows 10 64 bits updated
rx 590 fatboy 8 gb
ryzen 5 3600
mobo is gigabyte b450 gaming x
2x8gb 3600mhz ddr4 ram from viper
psu is corsair cv650 650W
cpu stock cooler
 uh after opening the pc the only driver i installed was the newest gpu one and windows updated itself
i want to update the others but i cant see anything on my monitor
i also dont know how to enter bios or if it would help
https://linustechtips.com/topic/1251156-new-pc-has-problems-with-display/
so specs are
rx 590 fatboy 8 gb
ryzen 5 3600
cpu stock cooler
 make sure its seated in the slot good might have moved a lil bit after putting it togather and moving it
