Dear pc enthusiasts, im really really tired and mad about my pc and its stupid problems. One of those is coil whine.
I recently built a new rig on july this year to be exact, and my build had problems since day one.
The rig s specs are these CPU: RYZEN 5 3600, GPU: Rtx 2060 ventus MSI (Swapped for nVidia GeForce Gtx 1660 Super Gigabyte 3 fan model) , 2x8gb Patriot Viper Blackout ram runnung st 3600 mhz, MSI B450 Tomahawk MAX, Toshiba P300 2tb 7200 RPM, Adata SSD 256gb, Antec NE650M(Swapped today for be quiet straight power 11 750w), Cooler master mb600l case, and the hyper 212 be rgb cpu cooler.
I have insane coil whine when i play games, but when i run the stress test for the gpu it isnt so loud, but its constantly there i think. First i swapped the gpu, it was there again. Then after research, and consulting with people who build pcs, we came to the conclusion that it was the PSU, so today i swapped it for a brand new psu, loaded up the Witcher 3, and got disappointed again.
I dont really know what to do anymore, is it the GPU again? Im sorry of this post s place doesn't belong here, but i didn't know where else to put it.
Any help will be appreciated, thanks.
https://linustechtips.com/topic/1251045-coil-whine-problems/
Coil whine isn't really a problem beyond the noise. It's a physical phenomena of the cards electronics doing their thing. Some load cases will be worse than others and some cards will be worse than others. I have not seen any consistent reports of certain brands being better or worse for coil whine.
PSUs can have the same thing happen, however, I think this is more rare since PSUs in most modest systems aren't stressed to anywhere near max capability like a GPU would be.
I'm guessing you're still getting GPU coil whine. Your options are to live with it, RMA (if manufacturer considers coil whine something they will do an RMA for - many will not since it's not *technically* a problem), or return and try a different brand/model.
Do you game with headphones? I find once I'm in game and have headphones on any coil whine that shows up is really not noticeable.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1251045-coil-whine-problems/#findComment-14057594
Top 3 components to have coil whine are the GPU, PSU, and Motherboard. If you swapped the PSU and GPU but still have it, it's likely the motherboard. Keep in mind that coil whine is extremely common, and most replacements you get may still have it in some form or another.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1251045-coil-whine-problems/#findComment-14057839
Im curious, do you have coil whine?
Because im really noise sensitive, and spending a lot of money on a rig and still having it is really a big no no in my book
https://linustechtips.com/topic/1251045-coil-whine-problems/#findComment-14057960
 I did, when my FPS got above a certain amount my GPU had coil whine. It only happened in game cutscenes that have uncapped framerates, or in games where I got over 400fps. I broke the card in to get rid of it (max synthetic stress test for about 4 hours), which can work with some components that have it. Not to sure about motherboards though. You can also take your chances with an RMA or replacement.
https://linustechtips.com/topic/1251045-coil-whine-problems/#findComment-14057991
