post-17521-0-37906400-1367452149_thumb.j
Hi I have been using this case for my rig for two years now, and searching in the forum for builds and topics for this case I haven't seen that much so I was thinking to share with you what i have learn so far about this budget gaming case, a few exploits and also some bad things   :wacko:. I have seen a few people using 200 mil fans on top and front but what i haven't seen yet is 3 fans on front, and its true it just has 2 mounting points on the fornt at the botom facing the hard drives, but actulay on the 5.25 dryve bays the brakets that fix the plates make the perfect preashure to hold a 120 mil fan and also have a dvd drive no problem, even the spacing betwin the first and the tirth bay fits perfectly to the shape of almost any fan, in my case SilverStone Air Penetrators.
post-17521-0-04619100-1367452444_thumb.j
post-17521-0-14526600-1367452606_thumb.j
In the water cooling side aldow it has the holds to get tubing out of the case i dont know it has to much space, i was thinking on using two 120 mil rads and one 240 low profile on the top, all insite the case, but i gess i will only have slots for 2 hard drives and im not sure if i would be able to fit the 240 on top.
post-17521-0-75925700-1367452681_thumb.j
(lol those fans where moving fast wile the photo was taken)
Also i wuld like to point out that I have been plaing with the remuvabol 2.5 inch bay with i fownd increadibly usefull for managing cables and giving a distinctive look to the case.
post-17521-0-88304900-1367452822_thumb.j
It is not a lot but at least i hope that those ideas will be usefull to some one and tell me guys what do you think,
 I need to repaint the case and the hard drives bay T T what metode do you think is the best ? Also i want to get some custom cables but with the poor space behind the motherboard i dont know if i wuld fit an other 24 pin conector.
There are my spects:
Gigabyte x58A UD3R
intel i7 930 (D0) 1.25v 4.0ghz
Gigabyte 660 windforce oc
3x2gb patriot sector7 1600mhz
Corsair H70
850w Cooler master Silent pro
128gb Ocz vertex4
5 teras in raid 5
post-17521-0-65936600-1367452913_thumb.j
post-17521-0-10250800-1367453032_thumb.j
https://linustechtips.com/topic/12508-cooler-master-haf-912/
Sick Build!!! I have the same case, but you made the inside look amazing and the lighting effects take it to the next level! Any tips on painting it?
CPU: Intel i5 3570k @ 4.5 Ghz Cooler: Hyper 212+ GPU: MSI Twin Frozr 3 7850 Case: HAF 912 RAM: 2x4GB Corsair Vengeance PSU: OCZ Modxstream 600W Motherboard: ASUS P8Z77-LK HDD: 1TB Seagate Barracuda
https://linustechtips.com/topic/12508-cooler-master-haf-912/#findComment-133162
Nooo i paint it with army painter for warhamer miniatures but it gets scratched the first time you put the dor on T T.
That stinks, the build still looks nice though!
https://linustechtips.com/topic/12508-cooler-master-haf-912/#findComment-133209
  • 2 weeks later...
  • 4 months later...
Great case but we can agreed that dust builds up in this this fast.
2500k 4.0ghz,GTX 1070 oc,MSI Z77A-GD55,G.SKILL Ripjaws(4 x 2GB)DDR3 1333,OCZ Arc 100 240gb,Samsung Spinpoint F3 1TB,Corsair TX 750w v1,CoolerMaster HAF 912,Hyper 212 EVO
https://linustechtips.com/topic/12508-cooler-master-haf-912/#findComment-822229
I have a HAF912+, here is my cooling setup:
front: 2 Noctua NF-F12 and a 140mm bequiet silent wings 2 in the 5.25" bays ghetto mounted with zip-ties (all intake)
side: Noctua NF-P14 intake
top: stock 200mm fan outtake
rear/cooler(cm hyper 412s): NF-F12 as pull on cooler, exhausting out the rear kinda.
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
https://linustechtips.com/topic/12508-cooler-master-haf-912/#findComment-823312
