power draw
Go to solution Solved by Ankerson,
1 minute ago, truckerlenny1990 said:
ive found out. the hx is abit quieter better fan when it does kick in so hxi it is
You really can't go wrong with the HXI IMO.
gamers nexus's overclocks yielded like 380w or so for the tuf, oc performance has not be great on 3080s. 10900k pulls 250-300w depending on how much you want to overclock. noctua's nvidia's suggested 750w specifically accounts for a 10900k so that should be fine aside from extreme overclocking.
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054864
2 minutes ago, VeganJoy said:
noctua's suggested 750w specifically accounts for a 10900k so that should be fine aside from extreme overclocking.
think you mean nvidia, took me like 3 seconds
assume it's ~400W to include some headroom
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054873
5 minutes ago, VeganJoy said:
gamers nexus's overclocks yielded like 380w or so for the tuf, oc performance has not be great on 3080s. 10900k pulls 250-300w depending on how much you want to overclock. noctua's suggested 750w specifically accounts for a 10900k so that should be fine aside from extreme overclocking.
asus recommends a 850 watt psu im trying to get the system as quiet as possible one being by buying a high enough psu so the psu will go into zero fan mode most of the time except for hardcore gaming
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054885
so,
According to some testing the FE RTX 3080 and a 10900k use about 550W of power.
Now add to that 50w, because you chose an AIB and we are at 600w.
Now you could get barely away with a quality 650W, but if you want to do some overclocking or have a wackton of drives a 750w will be basically required, anyways you want some headroom, I'd say 850w seems like the best option for a high end system
Main PC [The Rig of Theseus]:
CPU: i5-8600K @ 5.0 GHz | GPU: GTX 1660 | RAM: 16 GB DDR4 3000 MHz | Case: Lian Li PC-O11 Dynamic | PSU: Corsair RM 650i | SSD: Corsair MP510 480 GB |  HDD: 2x 6 TB WD Red| Motherboard: Gigabyte Z390 Aorus Pro | OS: Windows 11 Pro for Workstations
Secondary PC [Why did I bother]:
CPU: AMD Athlon 3000G | GPU: Vega 3 iGPU | RAM: 8 GB DDR4 3000 MHz | Case: Corsair 88R | PSU: Corsair VS 650 | SSD: WD Green M.2 SATA 120 GB | Motherboard: MSI A320M-A PRO MAX | OS: Windows 11 Pro for Workstations
Server [Solution in search of a problem]:
Model: HP DL360e Gen8 | CPU: 1x Xeon E5-2430L v1 | RAM: 12 GB DDR3 1066 MHz | SSD: Kingston A400 120 GB | OS: VMware ESXi 7
Server 2 electric boogaloo [A waste of electricity]:
Model: intel NUC NUC5CPYH | CPU: Celeron N3050 | RAM: 2GB DDR3L 1600 MHz | SSD: Kingston UV400 120 GB | OS: Debian Bullseye
Laptop:
Model: ThinkBook 14 Gen 2 AMD | CPU: Ryzen 7 4700U | RAM: 16 GB DDR4 3200 MHz | OS: Windows 11 Pro
Photography:
Cameras:
Full Frame digital: Sony α7
APS-C digital: Sony α100
Medium Format Film: Kodak Junior SIX-20
35mm Film:
Lenses:
Sony SAL-1870 18-70mm ƒ/3.5-5.6
Sony SAL-75300 75-300mm ƒ/4.5-5.6
Meike MK-50mm ƒ/1.7
PSA: No, I didn't waste all that money on computers, (except the main one) my server cost $40, the intel NUC was my old PC (although then it had 8GB of ram, I gave the bigger stick of ram to a person who really needed it), my laptop is used and the second PC is really cheap.
I like tinkering with computers and have a personal hatred towards phones and everything they represent (I daily drive an iPhone 7, or a 6, depends on which one works that day)
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054886
2 minutes ago, mbntr said:
so,
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054902
lol whoops lmao, thanks
i mean more isnt necessarily worse, ive had a lot of nice power supplies and never have i thought "gee that is a loud power supply." does everyone have super ultra silent case fans and cpu coolers? are their power supplies not tucked away and muffled under a few layers of sheet metal and cabling?
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054914
More wattage doesn’t mean quieter. Look specifically for a silence oriented PSU.
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054925
I'd say a seasonic or an RM850x, I've been really happy with the RM series, they are passively cooled until they reach a certain threshold, even when the fan is on (in my case I had to manually power it on because the load wasn't sufficient) you don't really hear it
Laptop:
Photography:
Cameras:
35mm Film:
Lenses:
Meike MK-50mm ƒ/1.7
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054926
Just helps when I’m trying to watch a movie not hearing a bunch of fans going. I have a phantoms p600s 6 noctua nf-a14 chromax black fans. Gonna buy a noctua nh-d15 chromax black cooler. And do a bunch of testing to get the setup as low noise as possible during video watching
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054929
How much the system can draw when watching a video?
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054938
yes excatly im trying to get the psu to go into zero fan mode when daily tasking for things like youtube, movies, facebook, and web searching. i dont mind it kicking in when im playing games as im sure all the fans will kick in then
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054966
i mean unless you think watching some videos will use a noticeable portion of a 3080 lol, a decent quality 750-850w wouldnt spin up the fans for that. usually they spin up around 40-60% load, depending on the model. the p600s has good sound proofing though, id be genuinely impressed if youd be able to hear the psu fan at all in any scenario.
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054969
im just trying to build the quietest pc i can build but have enough power to play games when needed.
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054977
thats fair but noctuas plus any decent psu (rmx, prime ultra, etc) would be more than enough. overkill, even, as some arctics plus a lesser psu (rm, focus plus, other cheaper good models) would be quiet while saving you a significant amount of money. the gpu and cpu coolers are usually by far the loudest components of most builds, making the sound dampening of a case the most important part for noise levels.
https://linustechtips.com/topic/1250775-power-draw/#findComment-14054990
Well then you would need a quiet PSU and fans.
My system below is VERY quiet as in you have to put your ear right next to the case and it's a high air flow case to barely hear anything.
Running all Noctua 140mm fans, 2x in front, one in back and the NH-D15 CPU cooler.
Corsair HXI 850W PSU.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
https://linustechtips.com/topic/1250775-power-draw/#findComment-14055009
i looked at rm850i, hx850i, rm1000i, and hx1000i both 850 watts psu fan turn on at about 325 watts while both 1000 watt psu fan turn on at 400 watts.
i choose a quiet case, noctua nh-d15 coolers at low fan speed is very quiet, 6 140mm noctua fans fan controlled with a corsair commander pro will allow me to set the fan curve quite high so everything is very quiet last thing needed is the psu to be quiet
https://linustechtips.com/topic/1250775-power-draw/#findComment-14055016
im trying to see if the psu will go into zero fan mode most of the time with my specs with a 850i or do i need a 1000i to go into zero fan mode
https://linustechtips.com/topic/1250775-power-draw/#findComment-14055026
I have mine set to run at 750 rpm and I can't hear it.... At all.... Quiet fan curve... ;)
That's how quiet the fan is on the HXI 850W...
https://linustechtips.com/topic/1250775-power-draw/#findComment-14055030
Just now, Ankerson said:
I have mine set to run at 750 rpm and I can't hear it.... At all.... ;)
idc how low it is or if you can hear it. my goal is to put the psu in zero fan mode if you cannot help me achieve that then why respond?
https://linustechtips.com/topic/1250775-power-draw/#findComment-14055038
I don't run mine on zero fan mode because the PSU in the basement of the case with little airflow so the temps tend to get in the 37C to 40C range normally. With the quiet fan profile it's in the 25C range.....
But yeah at default the fan never ran until I was gaming...
https://linustechtips.com/topic/1250775-power-draw/#findComment-14055056
i have a phanteks p600s with 3 140mm noctua fans as intake up front one which is about 2/3 pointing towards the basement where the psu will be. while the psu fan will be pointing downwards and the exhausting out the back im sure there is plenty of airflow. my apartment is air conditioned and quite cool on a regular basis. i bought a hx750i for my last setup and i just couldnt get it to go into zero fan mode and i hated it annoyed the heck out of me while watching a movie last setup was a 9700k and rtx2070 which got ruined from a flood.
https://linustechtips.com/topic/1250775-power-draw/#findComment-14055081
