Hey guys,
Just got a 3950x and no matter what I seem to do it the temperature is always really high.
The idle temps are between 60 to 70 degrees with nothing but Ryzen master. I've tried to lower the voltage but that doesn't seem to affect it. When I run cinebench r20 it pegs it at 95 degrees and throttles down to 1.8ghz giving me a cpu score of 4700.
I upgraded from a 1700x and never had an issue with it before
Specs:
Ryzen 9 3950x Corsair h110i gt Asus crosshair vi hero -x370 Bios :7901x64
Any idea of a fix or is it just a dead CPU!!
Thanks in advance
UPDATE:
without me changing anything I turned it on today and the idle temps are bellow 40 degrees and max out at 65 degrees in cinebench r20 giving me a score of 7300 at 4.1Ghz. No idea what has happened
Edited by romsmedia
https://linustechtips.com/topic/1249668-3950x-overheating/
You need to put a heatsink fan or some other cooling on it... Since you didn't provide that info, I will assume you aren't using anything :P
But in all seriousness though. What is your cooling solution?
Edit: duh I see it now... h100i... hmmm is that a new AIO or the old one from the 1700?
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14044921
I see he said a Corsair h110i gt
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14044927
that's abnormally high yes, especially for a 240mm AIO
can you try resetting CMOS? just in case you had some iffy settings in there
can you feel if the radiator is warm/hot?
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14044950
2 minutes ago, Bad5ector said:
If it was the old one from the 1700x, maybe double check that it is making good contact with the chip? If it is a new one, double check that you removed the plastic from the block.
old one, I've tried to reset it a few times and when I removed it looked like it was making good contact
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14044956
yeah ive reset the cmos and tried even lowering the voltage as it was originally at like 1.4V
Radiator is getting a bit warm and the tubes feel warm as well
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14044972
Might need to re-install the cpu block and re-apply new thermal compound
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14044983
2 minutes ago, romsmedia said:
yeah pump is showing up running at 3120rpm
Yeah, those temps don't sound right. I mean I know it is a high core / thread count CPU so a lot of heat is going to be generated in a small space. But I would expect you wouldn't thermal throttle. At least not that much.
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14044993
idle at 1.4v is normal for ryzen, what voltage did you set? hopefully below 1.275v because or else it's gonna be hot running chip
at stock it should lower to about 1.275v when under load, but idle above 1.4v
at least we know it's doing its job
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14045004
i set it at 1.25V and it was still giving me 55 degrees
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14045012
1 minute ago, HowardYing said:
so stats for me, I've had my PC set between medium and high on folding the past 3 hours. I got a 3950x, cooling with a nh-d15, and I've yet to hit above 83
my next step will be to try my old v8 gts and see if that explains
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14045021
that's pretty standard idle temp for 3950x and 3900x
but can i get a screenshot of your ryzen master?
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14045022
1 minute ago, romsmedia said:
can you run cinebench R20 for like 3 second and screen cap ryzen master?
it looks like your voltage setting didnt get applied, it's at 1.38v (at idle, at least)
https://linustechtips.com/topic/1249668-3950x-overheating/#findComment-14045046
