Budget (including currency): 50000 INR
Country: INDIA
Games, programs or workloads that it will be used for: Mostly productivity workloads like accounting software and Excel and chrome
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have the peripherals already
Parts list -:
Help me choose a MATX  case
https://linustechtips.com/topic/1249056-build-advice/
In your case you could actually consider an AMD APU and save money on the graphics card. If you go with your setup I'd recommend getting a B550 based motherboard instead, this would allow you to upgrade to a faster processor in the future and if not, would raise the value if you were to sell it in the future.
https://linustechtips.com/topic/1249056-build-advice/#findComment-14039957
If you are going to do such small stuff get integrated graphics instead that GPU isn't so good
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1249056-build-advice/#findComment-14039959
