Hello,
These are my specs:
AMD Ryzen 7 3800x
GeForce 1080Ti
850W PSU
16GB Ram
Asus B450-F MB
Noctua NH-D14 Cooler
I tried the automatic CPU overclock in the Asus AI Suite 3.
It had a stable OC at 12% Increase "From 3900 MHz to 4375MHz"
It works fine i havent had any issues in games yet.
But my problem is that the computer wont turn back on from sleep mode. I have to physically turn it off and on for it to power back on from sleep mode.
This happened after the OC anyone know what i can do to fix this?
https://linustechtips.com/topic/1248493-ai-suite-3-cpu-overclock/
Won't wake from sleep suggests it's not really stable, either quit using sleep, don't use the AI suite OC (those auto oc programs are garbage anyway), or manually oc. I reckon you could get 4375 running on 1.25-1.3v
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
