probably a bug. run cinebench or something and check the temps while ti is running
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1248411-cpu-maybe-overheating/#findComment-14034425
Easy check would be to open your system and touching that small silver heatsink on the motherboard. If it is hot that's ok, if you feel the heat before you touch it, that sensor readout maybe right. Still at that temperature, the board should have cut the power already and should refuse to boot up. I am betting on either a wrong readout of the sensor or just a bad sensor in the first place. If the board was that hot, it would heat up the GPU and the CPU as well. Something you can check.
https://linustechtips.com/topic/1248411-cpu-maybe-overheating/#findComment-14034458
i did what you said my cooler is cold and can you tell me what is cputin
https://linustechtips.com/topic/1248411-cpu-maybe-overheating/#findComment-14034507
