Hi everyone! My case, the Corsair RGB 220t Airflow has a maximum CPU cooler height of 160mm. The CPU cooler that I want to order is 158mm+3mm for the cromax heat sink cover. Normally,. I would avoid this because its too tall. However, On PcPartPicker, I saw a build with the same parts, and it looked like it fit. If someone could give me some advice here it will be much appreciated. :) Thanks!
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1247590-help-with-cpu-cooler-case-clearance/
1mm probably won't make or break you.  It sounds like the heat sink cover is removable anyways, so worst case scenario, you'll just have to take it off, right?
#Muricaparrotgang
Folding@Home Stats | Current PC Loadout:
Small                        Bigger				Biggerer				Biggest
Fractal Design Focus G       NZXT H1				Lian LI O11 Dynamic XL			Fractal Design Meshify C
FX-8320                      Ryzen 3 3200G			Ryzen 5 3600				Ryzen 7 3700X
120mm AIO                    120mm AIO				Custom 280mm loop			Noctua NH-D15
A motherboard                ASRock B450 mobo			MSI x570 mobo				MSI x570 mobo
16gb DDR3                    16gb DDR4 @ 3200			16gb DDR4 @ 3200			16gb DDR4 @ 3600
a melange of HDDs/SSDs       WD 1tb m.2				WD 500gb m.2				WD 1tb m.2/2tb HDD
PNY GTX 1070 x2              GTX 1070				GTX 1070 FE				MSI RTX 2080 TI
some 650w PSU                650W SFX-L 80+ Gold		MSI RTX 2080 Super			EVGA SuperNova 750w 80+ GOLD
								Corsair RM850x 80+ GOLD
Yeah i guess, but to get the heat sink cover is like $15, its only $15 but still don't really wanna spend that and not use it...
Fair enough.  Do you have a pc part picker account?  I feel like it lets you comment on builds -- maybe you can ask the person with the build (or anybody there who may have actually built it, if it's a generic build) if there were any clearance issues?
#Muricaparrotgang
Yeah, I do. I forgot about that. But, I think i'm just going to go with a different cooler with same thermals fro less, thank though!
