Hi, im from Argentina, this is my second post.
Budget (including currency): $700 USD (Aprox $80.000 ARG pesos)
Country: Argentina, Buenos Aires.
Games, programs or workloads that it will be used for: Apex Legends, Doom, Dark Souls 3, Cinema 4D and Blender
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I already bought a Motherboard, a Asrock B450M pro 4.
I was thinking of buying:
CPU:Ryzen 5 3600
GPU: msi GTX 1650 Super
RAM: Corsair 8Gb 3000Mhz x2
SSD: M.2 WD green 240Gb (For Windows OS) and a WD green SATA SSD 1TB for storage
I already have a case (Sentey CS1-1398) and a Power suply (Noganet 500w ATX P4)
The idea is to have a decent gaming pc while being able to do some 3D renders in Cinema because right now i have a HP Notebook with and i5 7th gen and i donw feel comfortable leaving it rendering for long periods.
I hear all your suggestions and questions
https://linustechtips.com/topic/1247141-first-pc-i-ever-build/
all looks good apart from this. it's pretty expensive for what it is.
i would look for a used gpu, for the same money as a new 1650 super you might find a 1070 or 1660ti
https://linustechtips.com/topic/1247141-first-pc-i-ever-build/#findComment-14023747
Thanks! i will check if i find one thats cheapier
https://linustechtips.com/topic/1247141-first-pc-i-ever-build/#findComment-14023796
