I'm having a hard time choosing a mechanical wireless keyboard. The budget options aren't wowing me and the ones I like are way too expensive.
Budget: $150
Must have: wireless, mechanical (brown or blue preferred), backlit (rgb not required), 2.4 GHz connectivity
Thanks for any recommendations!
https://linustechtips.com/topic/1246405-seeking-wireless-mechanical-keyboard/
Are the logitech lightspeed connection some kind of 2,4 GHz ?   Maybe you could look at logitech offering if fast wireless is a must.  Not sure about the build quality and the switches tho as i've never owned a logitech keyboard and I've never looked into getting one.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
That is correct, Lightspeed is Logitech'd special implementation. Corsair has "Slipstream wireless" as well.
