I am new to PC building game. And I ask for help about my issue.
I cannot change my monitor's refresh rate in the advanced adapter settings it is stuck to 60hz even though it is advertised as a 75hz monitor (Nvision XC24S). what should I do to change it. It has only VGA and HDMI ports.
My GPU is a RX 570.
https://linustechtips.com/topic/1246354-issue-about-refresh-rate/
hmm... it should have a 75Hz profile if it is advertised as so
but you can try creating a custom resolution for it in radeon software
gear icon -> display -> custom resolution create new+ on the bottom right of the page
edit: how did you connect the monitor? HDMI?
-sigh- feeling like I'm being too negative lately
  Reveal hidden contents
I tried setting a custom profile but it says it is not supported.
yes via the included HDMI from the unit
hmm that's weird
what cpu are you using?
2 minutes ago, Alfred Moscosa said:
I'm using a ryzen 5 2600
ah, no other GPU to test then?
check your monitor's OSD like Tan mentioned, maybe you have to turn on OC mode or smth
5 minutes ago, Tan3l6 said:
Maybe monitor on-screen menu has option to enable "OC"
I tried that but the menus of the monitor is pretty dry and has only basic functions and the pseudo HDR setting.
does Changing the Cable help? I am using the HDMI cable on the box
