Could you look at this PC part Picker list and see if the power supply has enough connectors for the Ryzen 5 3600 and a RTX 3070 founders edition.
I am new to PC building and saw theirs only 2 8 Pin connectors but the motherboard needs one and the RTX 3070 Needs 2, but PC part Picker doesnt say any issues.
https://pcpartpicker.com/user/NewBoi4321/saved/#view=JVPzf7
https://linustechtips.com/topic/1246099-need-help/
The eps connector and the pcie connectors are different things.
Budget for a build though? The cx is perfectly fine it's just I would probably pair. 3070 with something better.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1246099-need-help/#findComment-14015557
