restart the computer and press the key to enter bios when you see the board's logo (most of the time it's delete key)
in the bios, enable XMP profile, then save and exit
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1245928-ram-problem/#findComment-14014108
yeah i did it it said disabled then i clicked on it it didnt say enable but said profile 1 so i chose that and saved and exit now what
https://linustechtips.com/topic/1245928-ram-problem/#findComment-14014778
what's your RAM speed now?
https://linustechtips.com/topic/1245928-ram-problem/#findComment-14014786
🦀 your quote is gone 🦀
yeap, it's running 3000MHz now
it's reporting as 1500MHz, but DDR = Double Data Rate, the true frequency is half of advertised frequency (true frequency's proper name is Megatransfer/s, but almost no one refers it that way)
https://linustechtips.com/topic/1245928-ram-problem/#findComment-14014805
its the same to me can you tell me what to look at everything in the pics before and now look the same
https://linustechtips.com/topic/1245928-ram-problem/#findComment-14014859
before
after
first photo in each of the three you posted, near the middle
it was running at 2666MHz (1333*2), which is its JEDEC speed (speed of which it operates to make sure it posts when inserted into a new system)
when you enabled XMP, it'll run at its rated speed at 3000MHz (1500*2)
JEDEC speed
hope I explained it well enough :)
feel free to ask if you don't understand anything
https://linustechtips.com/topic/1245928-ram-problem/#findComment-14014874
