I love the size, but it only is 1 slot :(, so I was wondering, could I get a mITX MB tray, scoot it over to opposite side of the slot more & replce the backplate with a 2 slot BP? If I could find a CAD file somewhere I could just widen the case a bit.
GIGA AORUSBYTE B550I PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/1245678-element-q-adding-another-slot/
  • 2 weeks later...
It may be possible but probably more hassle than it is worth, you could always get a similar for factor case with the added cost and time to modify the current one.
https://silverstonetek.com/product.php?pid=536&area=en
