Ups beeps
850VA UPS has 510Watts available or is it an 1100VA UPS with 850Watts?
UPS will beep when you are drawing more power through it than the internal electronics by design can supply and it starts discharging the battery to make up the difference. This also happens when your outlet cannot supply enough power to the system (like having a kettle and hairdryer plugged into the same outlet) to try and supply the extra power needed the UPS will make up the difference with battery power and beep because it is discharging the battery.
"Understanding Volt AMP (VA) rating:
The VA rating of your unit represents the volume of electricity that the unit is designed to protect. Exceeding the VA rating of your ups is a common cause of UPS problems, even when the power is not out."
http://www.refurbups.com/Understanding-What-Volt-Amp-VA-Rating-Means
