fan extensions
ok so im doing a new build 10700k rtx3070 (when released) build wont be fully finished but im starting to order parts that im not concerned about testing to much. like fans, fan controller, case etc
i was inputing 6 noctua nf-a14 pwn chromax black fans into a phanteks p600s and noticed even with the included fan extensions im still gonna come up short if i want to put the corsair commander pro fan controller in the "basement" is there any restrictions or issues with plugging multiple fan extension cables into a single fan. i have 6 140mm fans and there is 6 fan headers on the controller so i wont be doubling up at all the cpu fans from a noctua nh-d15 chromax black will be plugged directly into a asus tuf z490 plus wifi
https://linustechtips.com/topic/1245251-fan-extensions/
Those fans aren't RGB so the Commander Pro would be a waste. Just grab a standard PWN fan hub with enough fan headers. The Corsair Commander Pro is specifically for RGB fans and LEDs and is like $75 in the US. You can get an 8 header standard PWM fan hub for like $25 in the US, Silverstone and Phanteks make them.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1245251-fan-extensions/#findComment-14008744
i want something made my corsair because i like the corsair software. and i might put a couple led strips in which i can use the corsair software for, plus it has temp control which i like using. not to mention the phanteks fan controller only holds 2 3 pin fans and 4 4 pin fans. i need 6 4 pin fan controls. i know i could buy a splitter but that defeats the purpose of having full control
https://linustechtips.com/topic/1245251-fan-extensions/#findComment-14009118
You are bit wrong there. Commander Pro is fan controller, and only recently added RGB options. Its not specifically made for RGB, Corsair has two other controllers for that.
If you like Corsair, go Corsair. Just note that Corsair is ecosystem. For LEDs they use proprietary connectors. While you can get adapters from standard ARGB to Corsair, the point is to get Corsair and only Corsair. Fan controls are universal.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1245251-fan-extensions/#findComment-14011072
I plan on buying a Corsair psu and even ram although ram will be basic 3200 MHz ram no rgb. My fans are nocturnal nf-a14 chromax black but my consent is that even with one fan extension it still ain’t long enough is it ok to use multiple extension on one fan
https://linustechtips.com/topic/1245251-fan-extensions/#findComment-14011217
