Eclipse P500A Riser Cable
Solved by Entropy.,
31 minutes ago, Loli Pits said:I'm planning to mount my GPU vertically... will any riser cable work or do I have to buy the Phanteks one?
Uhm most will work, But I'd reccomend something like the cablemod riser/bracket, and using the horizontal mounts instead of the vertical mounts. That'll give your GPU more room to "breath." If you put on one of the two integrated mounts, It probably will raise the temperatures ~10c or so over normal under load, since the GPU will be quite a bit more chocked then it would be if it were mounted with a custom braket, or just horizontally.
